Switched power in the trunk?
741 views 3 replies 3 participants last post by  Davids2013chargerrt
I would like to hook up a subwoofer amp in the trunk of my 2013 R/T. I have been having trouble finding an amp that turns on via the speaker level inputs. I would like to install the unit myself and do not want to run a wire to the front of the car or into the cabin. I know there is a power outlet in the back of the console that is switched. Does anyone know if there is a switched source of electrical power in the trunk that would be on whenever the car is running or in the account position?
#2 ·
I'm using a Kenwood KAC-8105D for my sub amp. It has speaker-level inputs with signal sensing turn-on that works like a charm. It's a discontinued amp but you can still find them. The replacement amp is the 9105D, and it also has speaker-level inputs with signal sensing turn-on.
